This is for the search engines. Someone will be trying to figure out how install the Scat Universal Linkage (30050) for dual Kadron carbs.
The provided instructions suck.
I've hacked together the best known install procedure for these carbs. I will post pictures later.
1. Remove all of your old Kadron linkage.
2. Remove your distributor - it will just be in the way.
3. Remove the throttle arms off your Kadrons (the old linkage used to snap on to the ball at the end of each arm). Keep these handy as you will need them again.
4. The new kit comes with block of metal that the throttle linkage pivots on - there is a little arm that will connect to the bottom left spot on the fan shroud. You need to make a modification to this arm.
a. Get a Dremel with a cutoff wheel and remove about a 1 inch wide by 3/8 inch deep section out of the top of the arm that extends from the block to the shroud.
b. This will allow enough clearance for the linkage to properly pivot.
5. Install the block and arm as described in the instructions.
6. Since you have the dremel out it is time to modify the throttle arms.
7. Use the Dremel cutoff wheel to remove the ball from the throttle arm. Cut it flush to the arm.
8. Get a drill and drill out what is left of the ball so there is a hole in the throttle arm.
9. The throttle arms will be installed with the "step" towards the rear of the car on the carbs at the same angle as before.
10. Use the hex head bolt and nylon nuts to attach the linkage ends to the throttle arms (it will be easier this way).
11. Install the linkage onto the pivot block. You will probably need to unscrew the passenger side linkage to get it under your alternator/generator.
12. Put the arms provided with the kit on each carb. You should have the throttle arm, the new arms, the lock washer and then the nut (in that order). The new arms should point towards the drivers side so that if you push up on the arm, the throttle will close on each carb.
13. Get a return spring for each carb. Attach the spring between the new arms and the top of the carb (you may need to fabricate something to hold the spring).
14. Adjust the linkage so that when the throttle is wide open, both carbs hit the stop at the same time.
15. You may only need to use one carb to adjust the idle position.
Here we have the driver's side carb. Note the two arms - original modified with step towards the rear of car and the other arm used for the throttle return spring. I used an old binder clip to make a spot for the return spring to connect to.
This is the passenger side carb. I bought an extra spring at NAPA.
It is hard to see - under the bar extending diagonally from top left to bottom right is the mount bracket that needs to be notched to clear the linkage
This shows how the linkage needs to connect to the old arms after they've been modified.
http://www.thestofans.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=7025&g2_serialNumber=2
