Author Topic: New '66 Project  (Read 12256 times)
May 11, 2011, 07:17:04 PM
Reply #210
Hey, you drive by too fast for me to get outside stalker!  :rotflmao:
But seriously, it sounds good  :2up:
May 11, 2011, 08:56:54 PM
Reply #211
So are you thinking 2, 3 or 4 inch narrowed beam on that beast?
May 12, 2011, 05:23:06 AM
Reply #212
Not sure yet.  I want to run air in the front when I do replace the beam, but I need to build up some funds for it.
Sent from my iPhone using Tapatalk
May 12, 2011, 07:54:10 AM
Reply #213
Online LooseNuts
I don't know about them cables, but them carbs sure are purdy  :2up:
hey this is a VW forum.   :slam: who the hell are you using someone else car as a avatar. why dont you go to gheyjeep.com and sling poo poo over there.
 :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao: JK
MAtty
HUGS   :gayfight:
May 12, 2011, 08:17:37 AM
Reply #214
Didn't know I was trash talking, sorry if I offended your thread Duane.
May 12, 2011, 10:28:06 AM
Reply #215
nah - J was just giving you crap about having that f-- c----- as an avatar.  You don't own it anymore....  :rotflmao:
If you are going to have the pic of someone's car as an avatar - at least pic a cool one!  :rotflmao: :headbang:
May 12, 2011, 11:21:17 AM
Reply #216
Online LooseNuts
:rotflmao:
come on Matty I know being a jeep owner didn't make you all soft on us now did it.   :dontknow:
MAtty
HUGS
:gayfight:
« Last Edit: May 12, 2011, 11:23:41 AM by LooseNuts »
September 06, 2011, 10:01:01 PM
Reply #217
Monday morning I went to the pic-n-pull with Kev to help him find some EDIS parts.  I ended up getting a free part out of the deal - a throttle position sensor.  Now to figure out a way to mount it...
Option 1. Mount it to the center of the linkage at the pivot point
Option 2. Mount it to one of the carb throttle body shafts
September 07, 2011, 06:52:37 AM
Reply #218
And just what kind of fun things are you going to do with this fancy part?
September 07, 2011, 07:38:40 AM
Reply #219
MegaJolt can use the input from either a MAP (manifold pressure) or Throttle Position sensor for engine load.  The MAP sensor hasn't really worked out for me, so I am going to try out a throttle position sensor.  Just need to figure out how to mount it.
September 07, 2011, 09:42:32 AM
Reply #220
And once he figures it out for himself, he can rig it up for me as well!!!!
And thanks Duane for going with me on Monday.  That was an awesome amount of help!
November 16, 2011, 09:38:34 PM
Reply #221
According to questionable sources - I was spewing smoke and oil last week as I left the meeting.  While I assert it was a simple case of horsepower trying to get out - I did notice some smoke in the rear (although that could have been coming from another white VW nearby).
So - yeah - maybe it was leaking a little bit.
Recall that I tore the motor down in September after I destroyed the clutch to swap out the cam and fix the oil leak.  Recall that it leaked out like crazy at the last Hot Dogs & Hot Rods.
So about a month ago I bought some spring loaded push rod tubes and installed them on the drivers side.
Except it began to leak even more.
So I was about to coat the stupid things in sealant and tape them up.
Except I still had four more tubes laying around the garage.
So I was putting them together the other night.... when I realized I had a bunch of "extra" o-rings (that go on the ends).
Actually I had 8 o-rings left over.
Why would they give me 8 extra o-rings?
Ah - I see.
Because each tube requires 3 o-rings - one on each end and one that goes in the middle.
Oil leak is fixed now.
November 17, 2011, 08:42:19 AM
Reply #222
 :rotflmao:
Nice job the man.
November 17, 2011, 10:19:05 AM
Reply #223
