Author Topic: if not one thing...  (Read 695 times)
April 10, 2007, 06:50:57 PM
azilla
so get a fuel pump from discount auto import on hall,
get it put in
car ran for bout hmm 20 sec  mmmm 40horses
then dies
and cant get it to really turn over
the starter now seems to not wanna catch the flywheel
hell sounds like its jsut having trouble turning itself over...
just acts like its trying itself to turn over
yet the engine turns over by hand just fine
any ideas?
sorry i cant make meeting like i planned i thought it was at the round table on tv that is closer to me..and since i work graveyard i wont have time to make it to work on time
April 10, 2007, 10:14:14 PM
If it only ran for a few seconds, it was probably only the fuel left in the carb bowl that kept it running.
Check the pump and make sure that the fuel pump rod is in there and that inlet is really the inlet.  I had connected my pump up wrong a few weeks ago.
-Duane
April 10, 2007, 10:33:57 PM
azilla
fuel line into bottom part
to carb on the top
donno if was fuel left in carb cause i ran that out the other day when i dumped gas in it
will look more at the thing tommorow with more sunlight see whats going on what could cause it
just happy it ran for the 20sec
longest its ever ran
April 11, 2007, 07:27:00 AM
Don't assume it is line in at bottom and out at top.... I made that assumption and it was wrong.
Check the top of the pump and see if there is an arrow pointing "in".
If you got an aftermarket "Brazilian" pump it might be reversed.
April 11, 2007, 08:07:25 AM
azilla
lol wow you are right
will do this when i wake up *graveyard shifter*
i looked at the brosol box and after translating the Portuguese to english the top in the entrance of fuel bottom is the exit of the fuel
thanks for the heads up
Quote from: "BuginU2"
April 13, 2007, 03:19:28 PM
Did it end up working out for you?  I had a really bad time dealing with fuel system problems on my 66.
April 13, 2007, 11:37:03 PM
azilla
between the crappy weather and my ankle acting up i havent been out there to to check on whats going on with it..
April 14, 2007, 07:35:15 PM
azilla
going to have to pull engine it seems
 either starter or clutch having issues
put car in gear  pushed it and engine doesnt even turn over
