I have decided to sell my Jetta project to help fund my bug motor. I really don't want too. But reality says I have too... Curse you reality!
Here is my ad copied from CL. I would be willing to take $500 from a club member.
Here is ad:
First and foremost... The 17" WHEELS are not included with the car. I'm hanging on to those for my bug. So you will need to bring two of your own wheels. Also note that the car will have to be towed home on a dolly or trailer for reasons listed below.
Also note that if it doesn't sell in the first try. I will put in the time and effort to trouble shoot the corrosion or connection problem and I will not take less then $1,000 for it.
This is a one year only car and is some what rare. Only one I have seen in person. I picked this car up about 8 months ago in a trade of cars with someone else. Car ran when I got it. I would start it up once a month to keep battery charged and car in running order. And then the rains came. The front windshield leaked horribly. A lot of water has leaked down onto the fuse panel. Last time I started the car, it would only run for a few seconds each start. And now the battery has died. It should run again by taking the time to clean up the corroded connections at the fuse panel.
When I got the car, the front driver side tire looked off and it felt like the bushings in the front end were shot. I have since replaced with new:
Poly front end bushings
Inner and out tie rod ends
Ball joints
Strut bushings
Timing belt and tensioner
I also have all new master cylinder and brake shoes/pads that I bought that will be included in the deal.
So I have roughly $225 in new parts on or included with the car already. Also have used mk2 H&R drop springs in the front. I want to say the are 1.5" drop springs. Also have some for the rear but not installed.
After doing all of that work the tire still looked off. Upon further inspection I found out the the front control arm fork is bend slightly out on the driver side. It is a common thing on mk1 Vw's front end what I have been reading and told. Car will need to be put on a frame rack or use a come-a-long to pull the one side back over. Then you have to put in a lower stress bar is the way to prevent this from happening again.
Car does have a few dings and dents but nothing major that I can see. Does have some surface rust here and there.
Only reason I am selling is because my bug project has taken priority over the Jetta. So I might be interested in a trade of a running 1835cc or larger vw bug motor.
Other then that, I have a clean title in my hand for the first person to put good cash in my hand or drops off the motor I'm looking for. I may entertain cash + bug motor parts offers. No low ballers and if ad is still up, I have the car.
Here is a few more pics:
