The Rose City Volksters meet at 7:30PM on the 2nd Tuesday of each month at:Beaverton Round Table10150 SW Beaverton HillsdaleBeaverton, OR 97005Click here for map
Todays offeringRunning but not reallyPer Duane....I checked the valves and they were all at a snug .006. I checked the points again and set them to .016. I static timed to 10 btdc and started er up...the car is still popping and sputtering...from both sides....what I noticed today because I have the preheat tubes unblocked right now is that when I look in them and rev the engine I can see flame.....sooo...I am wondering if anyone has any other ideas for me....I am probably missing something simple but I cant for the life of me figure this out. the car idled a little bit today but it was because the throttle didnt return fully I think.The other thing that concerns me, and Im not sure its in the video...is this engine shakes like mad when its trying to idle...Im so far removed now from having a car that runs normal that I cant remember how much shake is "normal" when these things are sputtering a little.Anyway...Thanks for any input.
The Good:Kev lent me a sychronizer so I can do it right My car idled on its own for about 4 minutes today...it hasnt done that for a long time...it stopped when I cut the power[/liCar was running much smoother today...Static timed to 8 btdc and set both carbs idle jet out 2.5 turns (they were at 2 before)The Bad:Remembering I knew my problem would be something "simple"...I noticed today it was loping on the idle which led me to check for vacuum leaks....guess what I found where the manifold meets the head Next step is to get a new gasket and to retorque the intake on that side then to sync the carbs and see where we are
