Author Topic: Thanks Mark and Raleigh!  (Read 438 times)
July 07, 2010, 06:57:57 AM
I had a bit of a problem yesterday afternoon trying to drive home from work.  The bug started losing power as I left the office (around 25th in Hillsboro) and headed down Jackson School Road.  I first felt like I lost a spark plug wire (running on 3)... then 2.... then dead.
I was able to coast into a dirt road turn-out to survey the problem.  First thing I noticed was that my carb linkage was not synced up.  Unfortunately I did not have the right tools with me to fix it.  Since I still in Hillsboro - I decided to give Mark a call to see if he could lend a hand.  At that time he was leaving his office (in downtown Portland) and he would pick me up if I was still on the side of the road when they passed by.
I managed to fire up the engine and limp it back towards Mark's house.  It made it as far as Evergreen before it died again.  I was sitting on the side of Evergreen when Raleigh pulled up behind me and offered to lend a hand.  We were able to get it moved to a school parking lot on Evergreen where there was some shade.
Mark called back a while later once he got home (and didn't see me or my car along the route or at his house).  He brought some tools, a tow bar, and his red convertible (it has a hitch on it).  After some troubleshooting, it appears the EMPI electric fuel pump is crap - big surprise.  I am only getting a trickle of fuel to the carbs and it isn't filling the carbs fast enough to keep the car running (even at idle).  (the linkage wasn't the problem)
After attempting to make an almost idle only drive home Mark towed my car (with the red vert) back to his house and Raleigh gave me a ride home to Beaverton.  Late last night I drove the van out to tow it back to my house.
Big time kudos to both Mark and Raleigh for helping out a Volkster in need!  I really appreciate the time and effort you provided last night.  Thank you!
July 07, 2010, 08:12:50 AM
Let me know if you want a hand pulling your gas tank
July 07, 2010, 11:16:05 AM
Offline Ragtopboy58
No problem Duane, anytime.  Enjoyed visiting with you and Mark for a bit as well.  Was awesome to see Marks vert with the tow bar in backseat come to help out.  Totally wasn't expecting that.  lol  That was awesome!   :)
-Raleigh-
`58 Rag
`56 Oval
July 07, 2010, 12:02:17 PM
got your message late last night. I was out shoot and didnt have service till late :(
July 07, 2010, 07:46:36 PM
Well it looks like I am good to go now.  The fuel pump was officially dead in my book - took it back to DIP and swapped it out.
I also discovered that my fuel filter (next to the tranny) was having an issue.  I had a metal in-line filter there and the ends were breaking off for some reason.  So I replace it with a stock filter and now I have good fuel pressure.
Ran the pump for a few minutes to fill the carbs and took it for a spin around the block.  Problem solved for now..... ;D
July 08, 2010, 06:29:41 PM
Offline Ragtopboy58
Glad you got it figured out.   :)
-Raleigh-
`58 Rag
`56 Oval
July 08, 2010, 07:54:57 PM
If I read this right, you replaced a broken EMPI pump w/another EMPI pump???  :o
July 08, 2010, 10:05:59 PM
Uhhhh... yeah.  Certainly the second won't be bad too.... ah crap.  You are right - it is EMPI - I guess I'll save my pennies for a real pump.
July 10, 2010, 08:42:19 AM
that is the spirit that this club has been lacking in lately, good to so it again.
as far as your fuel filter what kind is it?  I can give you the number of the one I have under my car if you want.  It is a Wix brand from Baxters.  I can also make you a bracket like mine so that it is not free floating under the car putting unnecessary strain on the fuel lines.
godd to see raliegh back out too  :D
July 10, 2010, 09:59:31 AM
When we run across applications needing electrics at work we use Holley. I don't know if it's a good or bad pump (more so than say EMPI) but we have never gotten one back or heard complaints. Plus I don't think there most expensive pump you can buy if that helps in any way.
