Author Topic: A tale of shift rod bushings and fuel lines....  (Read 2169 times)
August 06, 2010, 08:05:29 AM
Reply #60
heh heh you said "cream their beams" heh heh
looks like fun stuff right there
August 06, 2010, 09:10:15 AM
Reply #61
There is always this stylish design to look forward to...
Slammed Bug Vs. Man-hole cover.  We will loose every time.  This is not my car but I have had my own experiences with raised man-hole covers.  It ain't all that fun.
August 06, 2010, 12:40:19 PM
Reply #62
Quote
Which is why I am going to break down and throw air on the front. That way I can hit a switch and raise up when needed.  ;)
August 08, 2010, 09:31:34 PM
Reply #63
I talked to a dude at PIR who had his car done by KCW. He said they have all quit running air on their cars. You lose a solenoid or a line while you are driving and you are screwed. Besides, ball joint beams don't really go down to mind blowing levels as it is. That is partly why J "creamed his beam" (that was for you Peter). He had his set where he liked his car to be. If he had a link beam in there he would have had 3/4 of an inch more clearance if not more. Probably would have cleared said manhole cover.
So put that damn thing in the tall weeds waldo...
August 10, 2010, 02:02:34 PM
Reply #64
Offline ruwaldo
  • Forum Moderator
Well the install is done. All in all it wasn't that bad. Had to cut on the car a bit thanks to changes made by the DOT in 74' but that was the biggest mod needed.
If you look to the right of the of the upper torsion tube you can see where I had to cut the frame. This cut had to be made to get the old beam out.
Getting the new 4" cut beam in was a bit tight, had to do a little pry bar lovin' to the shock towers to get it up and in place. Let's just say that there isn't an extra millimeter between the wheel wells and the shock towers.
Here it is with the torsion arms, spindles and shocks in.
So in the end I went back to the stock spindles. The beam gives me all the drop I want and with the castor shims behind the bottom torsion tubes the wheels are centered nicely in the fenders. At some point in the future I'll put disc brakes on the front and it's easier to find bolt on kits for the stock spindles. Also between all new tie rod ends and adjusting and tightening the steering box the steering is better than ever. All that is left to do is get an alignment though it's not too bad right now. It tracks straight and there is no shaking. I'm gonna drive it for a week or so and let things settle in, then take it in for the alignment.
Here is the end result.
« Last Edit: August 10, 2010, 03:37:23 PM by ruwaldo »
'74 Std. A work in progress. :)
My windows aren't fogged up, it's just a really good UV filter......
August 10, 2010, 03:27:00 PM
Reply #65
August 10, 2010, 06:44:32 PM
Reply #66
Dang, you could make it over curbs with that thing. You said you had speed bumps to worry about. Looks like that will be no problem.
Does look good in the car.
