Author Topic: corradojeff's second atempt at bug  (Read 3904 times)
April 29, 2010, 12:57:46 PM
Reply #45
Unless you plan on building an outright race car, just send it back and go with the stage 1, and yes DIP has them in stock.
April 29, 2010, 08:45:55 PM
Reply #46
Offline slammed67
Be careful when you ask for a stage one at DIP. When I did they slipped me an Empi instead.  Only charged me for an Empi but I had to take it back to get a Kennedy. I had no problem paying more for it:-)
Randy
Broken promises don't upset me. I just think, why did they believe me?
~Jack Handey
April 29, 2010, 09:09:06 PM
Reply #47
to get off the topic of clutch i started fitting the air ride bags in the rear. I am a fab genious! :o
April 29, 2010, 11:16:02 PM
Reply #48
April 29, 2010, 11:19:02 PM
Reply #49
To put you back on topic...
Broke clutch cable on my way home this evening (has Stage 1 in it).   >:(
April 30, 2010, 12:10:13 AM
Reply #50
 ::) Thanks Mark we can always count on you to guide us in example. Way to take one for the team man   :o  ???
April 30, 2010, 07:18:33 AM
Reply #51
that happened because you said that it has only happened in the bus you know.... :-*
May 23, 2010, 02:58:26 PM
Reply #52
bug is back on the ground happy and ready for bug run :)
May 24, 2010, 07:24:43 AM
Reply #53
July 10, 2010, 03:56:10 PM
Reply #54
He has pictures of the clutch up above in the thread Peter.
Show us pictures of the car on the ground dude.
September 11, 2010, 06:43:33 PM
Reply #55
Long over due update. The past couple months have been real busy with moving and work picking up the bug is tore apart ready to go under the knife. The engine will be getting pulled shortly also
so far i have all 4 fenders off. the frunk lid, all bumpers and the running boards are off as well. also pulled the tank out to make it easy to get to the beam when i need to.
this was also a good time for me to get close to the body and find all the problems with it. so far the majority of the damage i have found is in the right rear. the front apron looks to have been replaced atleast twice with some less then spectacular welding. the rear bumper bracket area of the body is all rotted out as well.
next up will be the removal of the deck lid and the interior fallowed by all the glass
 :cheers2: :driving:
« Last Edit: September 11, 2010, 07:14:00 PM by corradojeff »
December 04, 2010, 06:31:36 PM
Reply #56
December 04, 2010, 08:11:53 PM
Reply #57
That fibreglass is hammered.
Fun stuff maynard.
Oh and I'll let you know.....
December 04, 2010, 10:24:21 PM
Reply #58
fiberglass has been repaired from the back side and just needs to be filled and primed
December 05, 2010, 08:53:48 AM
Reply #59
Baja volksrod project???  :dontknow:
